viewer nx
  • Thread starter Thread starter punto
punto
Hello, should I view the files made with this program, that you know essite a free viewer?
There is no free viewer for nx.
the advice I give you is to send you to who has nx a file generated by xpresreview.
This file allows you to see these nx documents without having to install anything on your computer, also includes the tables if present.
the jt2go this possibility to see the tables does not possess it.
also with xpressreview other word documents, excel...etc. .
the advice is good, but to generate the pcf file you need a license.
if by chance the license was not available the only truly free method is to make an export jt from nx and use the jt2go.
the pcf (readed by the xpressreview) has the advantage tells us user nx ( attach office file) and the possibility to attach also the 2d (cgm).
the 3d of the pcf is always a jt.
What license are you talking about?
even with the basic license you can generate and by base I mean the mach1.
in the mach is included (from mach1 to mach4), but not in the mach1 advantage.
If you have the configuration "in modules" you must have bought it.
