views in section on table
  • Thread starter Thread starter d-prom
d-prom
Good evening, guys. I have a problem for which I tried to look on the forum but I found nothing.
we are in the design environment. I have a view in which it is seen, drawn of course, a hole, whose axis is parallel to the plane of the view itself. I want to make a view in section on this hole. How do I bind the section plan to the hole?
thank you 1000 in advance to those who will give me some suggestions.
- select the view (important thing)
- create a sketch (always with the selected view)
- in the sketch draws a closed form that will make from delimitation of the section (a rectangle or any form, as long as it is closed and that it includes inside the section to be dissected)
- Get out of the sketch.
- "create split view" command
- select the view you associated with the sketch
- in the window under the heading "depth" choose the option from the drop-down menu "at the hole" and click in the graphic window one of the dotted lines of the hole and the ok
