views with 3d assonometric sections
  • Thread starter Thread starter makeng
makeng
Good morning, everyone.
I use creo 2.0 parametric and I have a trivial need to insert an assonometric view into a "sectional" design. I consulted the help online and tells me to create "zones" dissected. basically refers to "visuality/management seen". I create a design, insert a main assonometric view, and in the "sections" window is not active "section 3d". only sections 2d. I also searched in the forum but found nothing. Maybe it's the usual hidden cauliflower, but until you know these things you crave in the dark, then as usual the solution makes you feel like a shady....
thanks for the help
Mar
thanks for the help
Mar
"section 3d" is only active, if in the extyrone model "zone"
cannot be created by the design.
hinges
