vincoli in rilievo
  • Thread starter Thread starter dicifa
dicifa
I have a problem to solve. . .
I have to make a presentation from a client...I have a set made up of so many sub-assistances where I go to suppress constraints to make the "movement", the only thing is that I have to go to look for constraints every time making me miss a lot of time: is there a way to highlight these constraints in the browser?
... I looked at the forum but I didn't find anything. .
Thank you. .
First you can call the bonds as you best believe and put them in front of a distinctive sign # for example. but the smartest thing is to create a configuration where you go to suppress constraints. Of course all the time is a menata.. .They are for that configurations, done once you only have to click on which configuration you want: normal or without constraints.
position representations could be the solution
-edit: I had not seen the previous answer. . . -
...because it wouldn't be bad as an idea...
I would say that it is the basic system that teach in all the courses of all the mdellators:wink: if there were no one could have no variability of anything
