virtual components
  • Thread starter Thread starter genesis1975
genesis1975
Good morning, I opened a subaxieme and then I created drawing from the axieme but I came this message (precisely I don't know what virtual components are)1570784792585.webp
I've read it before but it's not very clear to me... but if you can, in your words, what is a virtual component? and how do I do to continue in my design?
a virtual component is a component that does not have a physical file in the explorer folders. is present within the axieme, it is managed as any other part or subaxieme, but remains saved internally. the parts that are created directly in the axieme, i.e. without inserting a previously created part, is always a virtual part that at the time of the rescue is asked if to save it internally, then lascciarla virtual, or externally.
an example where it can be useful to use virtual components is the cylinder; the code is only one, but if you need to make movements you have to create a mobile assembly that will be composed of 2 parts (stelo and shirt). But it may be that in the explorer folder create confusion then they make viruali the two parts that will be incorporated into the axieme (which will have a greater weight mb).
files created directly in the mantan axieme, in the featur manger, the name imposed while the files that from outside become virtual take the suffix "copy of file name".
that message I have no idea of its appearance as if a file is virtual and I want it to remain virtual I do not have to save it externally. but how you managed the project you don't understand from the feature manager's screnshot.
to locate them in the virtual component feature manager are represented with the quad drawings at the beginning and end file name
the set that doesn't make me do the drawing because it contains still virtual parts if I do dx key gives me the option of 1.name it 2.to save it on an external file, and then it should be he to be virtual, only that if I go into the external list of the files he already appears then it should not be virtual.
I honestly don't remember what the 2012 version was doing, but I wanted to make a statement. the table of the assemblies that contain virtual composts you can do quietly. it is not possible to make the table of a virtual component, which must first be saved externally.
useful and interesting clarification. I never noticed it using virtual components in the way of the example I reported above. thanks to the info
I personally disagree with the use of virtual components, I used the system for a few months and then realize that sw without reason at a distance of months if it lost them on the street, you opened the axieme and virtual components were no longer in place.
if you use them for a short time but then save them immediately.
I never had a problem.
I use them every time I have a commercial component with single code, like cylinders and jacks, and I need to make motion checks.
also moving them from one folder to another keep their place.
Maybe you opened them while there was a part with the same open name.
