virtual memory 82%
  • Thread starter Thread starter piccio__87
piccio__87
Hello.
I have the virtual memory of inventor prof. 2010, as from title, to 82%, it is all quite slow... and the bar on the lower right that indicates the memory is red... (with 1 .ipt file open, a bit small but I can't do that differently, I don't dare imagine when I charge it inside the set, so....)
How can I give him some power? possibly without changing computers?? ? :
if you can try to use the levels of detail by suppressing as much as possible at least lighten it a little! where you can also try to simplify as much as possible the strange forms and holes slow down a lot
detail levels in ipt ?
Do you have the automatic projection of the active edges?
do you have adaptive work derived from particular contiguous tions?
Did you save the detail, turned off inventor and turned on?
Bye.
thanks to the availability, when I am in the office I answer everyone. ..however, I could simplify a little bit. . .
