hello to all,who can tell me why can't see the templates of the work?I only see some,but the holes can't...I can't find the templates of the holes etc...
no I didn't want to scare you the holes you can do great but the template as they mean in visicam is a file where operations are stored with all the parameters of both operations and cutting utnsile, etc. that you can recall in any file by associating the geometries of the piece to work there.
This speeds up work in case they have to make similar pieces.
if instead you have to wreck a drill just select the operation from the work strategies menu and apply them to the geometry to work:wiframe feater etc. if you do not have these defined elements he does not know where to drill.
