ocraM999
After completing all project tables, i.e. finished project, I am asked to add a plan in format.dwg.
this dwg will have to appear only in two/three views against the thirty that make up the project.unfortunately the design of autocad is seen in all the views.
at this point I should turn off to one at one in the graphical visibility settings
the intruder with the risk of having to repeat the operation all the times that the problem should be resumed.... that by the law of murphy will happen!
So, is there a way to avoid this fatigue?
Thank you
Thank you
