Visibility otas lines
  • Thread starter Thread starter Maxweb
Maxweb
Good morning, I have a strange request from a client:
I should be in print to delete the quota lines and extension, in a few words should remain only the value of the quota surrounded by the frame of the "tolerance method - base".
I do not know how to proceed because if I act on the layers I also disappear the text, there is another solution in mind?
thanks and greetings.
I think it will be a bit long, however: you create a custom quote style where the text is customized (basic type and special layer) and quota lines on another non-printable layer. When you put on the table for that client, use that quote style.
... I also wanted to proceed so but the quota text always goes inside the layer set for quotas.... At least it seems to me from the evidence that I did
In fact... I solved creating a custom quote style where in the display tab I set the white line.
Bad to see but when you print you don't see...
