visibility parts together
  • Thread starter Thread starter gil
gil
Hi, I'm asking for a delucid. we start from this or example
1) I create a set and inside I put some whatever object. each of these is a solid to which mediating sketches were made on work plans.
2) from the object browser, I remove the visibility one of these objects and then restore it.
3) at this point beyond the object we also see the work plans linked to the object with the shares of the sketches. I must therefore break the sketch of the piece to have a clean view.
the illustrated procedure is very uncomfortable if there are so many parts in the very near. can you overcome somehow? Thank you.
What release do you have?
in any case what you have to do is remove visibility within the parts and save them.
if you remove the visibility of the plan of the part in the environment together and then remove the visibility to the part and then restore it, the default values of the part will be restored at the time of its last rescue.
So, it seems to me that if you open the part with the plans (not edited in the axieme, just open in window to itself) all changes to the visibility of sketches and geometries are reflected in the axieme in all the occurrences of the object, and that vice versa if you make such change locally in the axieme the changes to the visibility do not reflect in the object itself opened individually (:confused: you understand?). I did a test and I think it works. . .
Bye!
(I anticipate my answer... )
