vista 3d impazzita!
  • Thread starter Thread starter bagiolino
bagiolino
hello to everyone, someone can tell me why (or if to any of you happened) every now and then when I design the 3d view makes me see the hidden lines even if they are in "shading with edges"? ?
Today I was drawing a steel scale (not very simple), when I finished it I went in 3d and noticed that all the design changed!
I attach an image to make you understand!
Yet my pc has 1 year of life and is not a nail!
the problem now is that if I close the file and reopen it does not change anything!
Good evening, everyone.
... if I don't remember badly, the problem has already been reported, but you haven't understood why it happens....
before writing I looked in the forum but I didn't find the discussion... If you find her, let me know I'm going to see her!
So what do you think I have to do?? Do I need to remake the drawing from head or is there a way to copy it on a new file (type "copy" and "paste" that you can do in autocad)?
good day and thank you for the answer!
send the file to autodesk assistance.
Have you tried to open a previous rescue?
Are you using the latest update?
I made the drawing first. .
I would still like to know why after a while I design the file goes crazy, I will try to look for similar discussions around the network and in case I find something I write it on the forum.
Thanks for everything and good work!
Hi, the same problem happened to me. I also called the assistance that remotely entered the pc and did not solve the problem...mystery?! I also opted for the redesign. If I get to some other solution I'll let you know. hello good work
the problem, even if momentary, is resolved by eliminating the view 3d and creating a new
:cool:
Did you say after a while? ... strange.
Try changing the car... so you know if it's a hard problem.
But the effect is not bad....
