vista esplosa
  • Thread starter Thread starter MaiMollare
MaiMollare
Good morning
My partner and I have a problem with explosive views. we followed the following steps:
1) we put ourselves in model mode
2) we positioned on the trimetric view making it work view
3) within this view we created an explosion1 and saved
4) we have passed fashionable put on the table and inserted the trimetric view but there is no way to see the exploded parts
5) we followed more than one tutorial on you tube, but we can't figure out where we're wrong. the view is always not exploded
you can give us a tip please, we use nx8
Bye.
Are you performing the table with master model philosophy?
in this case verify that for the table you are 'reading' the master model file and not the model of the 2d.
sent by my col-l29 using tapatalk
Aries.
I try to be clearer.
the previous answer was related to the first thing to check if you are in nx integrated with tc.
can 'capture' that if you do not use the master-model philosophy, when you make the table the 'high' model is not the master one, but the one present in the drafting file (and you did not create them your exploded view I imagine ).
in this case in the 'base view' window under the 'select part' (when you make the table ) you must be honest that you have selected on the icon representing a solid 3d (i.e. the master model ).
solved this first point, regardless of whether you are on stand alone or integrated, creates a dedicated 'model view' (e.g. call it exploded) in the modeling environment and in that view let the explosive view work.
When you go to the table, choose from the 'model view to use' the newly created view.
walà.
Hello bixel
I tried to attach a small video to show you what I did but also zipped there is no way.
I press that I work with the integrated release 8 with tc.
I managed to create my view exploded in the following way:
1) I put myself in the table in modalita modeling
2) I positioned myself in the desired view and then created the explosive
3) I saved the view by giving it a new name
4) I put myself in drafting mode and entered the view by selecting under loaded parts the desired model (see image)
5) at this point I can insert the explosive view that I had saved
in the 3d solid dialog box is always featured.
I would like to emphasize that I never opened the model, but I just worked on drafting.
the result I have reached it but still do not know if it is the most correct method.
as I said above:
if you use the master model filosofy:
- create the explored in the pure model in a dedicated view created specifically and let the explored view active in that view; then you can default the trimetric or the one you prefer
- in the drafting file that will derive from it, sincerely that putting the master model on the table
- select the view with the explosive (or explosions) to put on the table.
see Annexes
Usually, you do not create explosions or other interventions in the drafting file model if you follow the prosofy mm.
If you have other provisions at company level, you can replicate what I said in the draft model, choosing what you put the views, the model contained in the drafting file instead of the master.
p.s.
exploded view (as well as arrangement ) are not automatically reported in the drafting file model that follows..(at least so it is up to v. 11 ).
I have to try again in 1847..
ergo: if you do them in the master model file, you have to take them and vice versa.
That's the bixel point. If I work on mm when I go to insert the basic view, there is no choice option, i.e. I do not see the pattern in the dialog box, I like my colleagues. and that's why we're only working on drafting.
If you look at my dialog box missing that section dedicated to this choice, to me as to my colleagues, it probably depends on the release.
as I said above:
see Annexes
p.s.
I do not agree with how much you write in relation to where make the view exploded while sharing what he did @maimollare.
The reason is that the whole model does not carry unnecessary information that weighs the file for nothing, secondaryly in the drafting model you can put boundary geometry that does not end up in the geometry of the model together.
eye eye eye eye eye eye @maimollare that from the default release 9 you get the view of the model while in the release you use you get by default the view of the drafting.
I hope I've been clear.
@bixel is not telling you this, in the image you posted you see in the second line recent part that there is the possibility to choose the model as well.
what I wrote, comes from an answer I had a long time ago on gtac.
so I take it as best practice.
then, there is freedom of action.
you can make arrangement or explosions or in the master model or drafting model.
bixel the model is true that you can select it but on the table then I don't see it exploded and that's why I went to drafting, however I don't want you to waste any more time and anyway the result I reached it, thanks to all
bixel the model is true that you can select it but on the table then I do not see it exploded
obviously does not select the view created ad hoc in that context of assemblies on the master model, with the scanned view activated at the same time.
I'd say it's the only reason I can think of
it was enough to click from the 'recent part' the master model file where you created the explosive view (if you had done it there ) and further select the created view.
if it works by doing it on the drafting model, it also works by doing it in the master model.
less than other 'local' problems.
and that's why I went to the drafting, anyway I don't want to waste any more time and anyway the result I reached, thanks to all
excellent
