vista spaccata
  • Thread starter Thread starter tmeinventor
tmeinventor
hello to all
I have to perform a split view on a component made with the shaft generator, near 2 threaded holes where inside or inserted a screw with its washer
Unfortunately when I generate the split view using the sketch that I use as a contour of the split view itself, I don't "spray" the aber, then I tell him to split all the parts but also split the vine by making me see it dissected. . .
do you know if it is possible to determine the participation of the split view to the various components as for the section?
the exclusion or participation in the section I did it in the table, would you be so kind to indicate the percose in ipt environment?
Thanks again
Oh, okay, I thought you'd lose the same thing.
open the part (in your case the tree, I think it has the setting not to select active by default as you generated it with a specific module of inventor, the basic parts modeled have this active function and those generated disable), tools -> document setting, tab modeling and last part "setting"; if the check is present the part is dissected, if it is not present, it does not dissect.
Unfortunately in tree I do not see the section section in the modeling tab what instead I see in other ipts that were not genuine automatically by inventor.. .
But what I needed was not to show the crack in the screw...I don't know if the thing is analogous...but I can't find any way even in the table
open the tree part, not the tree, you will see that there is.
no, in the table or sections according to this setting the various parts, or sections everything, there is no other way.
