blubossa Guest Mar 19, 2010 #1 I can't see sketches are not in hiding..... how do I make them visible? ? Thank you.
denicolo Guest Sep 11, 2013 #2 same problem, I don't know how to view the sketch lines in the 2d and use them with "assi" cones to quote!! !
DANI-3D Guest Sep 11, 2013 #3 Hi. the layer where the sketch is located is active? is the problem only with this table, or is it general?
denicolo Guest Sep 11, 2013 #4 the layer is active! The problem is general! I noticed that if the scketch is outside the extrusion vien displayed in the 2d, if it is included in the extrusion tree it is impossible to view it! !
DANI-3D Guest Sep 11, 2013 #5 in the drw view, have you tried to choose to view hidden lines? What's going on?
