valeriob
hi to all solidworsians I would like to know the procedure that allows me to change a solid or totally closed (a full cube), or emptied (a cube emptied inside), or an empty but missing face (a bowl).
I found myself in front of this question when I had to model a watering machine, a coffee maker, a bowl. If someone knows how to do it, it could make me available to +o- simple examples to download (sw2008) as those I have listed.
I add: but if you want to know the volume contained in a container at various levels (100mm from the base or 50mm from the base) what is the + correct procedure.
