w.i.p 3 palazzine
  • Thread starter Thread starter jox1981
jox1981
hello to all I open this work in progress (w.i.p.) where I will model 3 buildings and the context, I started today with the ground floor of the first building, I will update the topic as I go ahead and then postero' the final renderings, program used : 3dstudio + vray :mixed:
here is a first rendering:
There should be everything: floors, locks, windows and walls.
raised floor modeled:
First floor:
second floor (I had corrupted the file and had to do it again) !!! :
Third floor:
Fourth floor:
(cut)
I don't know, but I smell gabber... .
Maybe it's just an impression... :
I don't know who it is.
However I went on:
Plan 5:
Plan 6:
Plan 7 :
Just a plan is missing.
I understand the wip, but these are raw shadates. When do you make them?
I'll make them when I've joined all the plans, so now I still have to figure out if I modeled everything in the right way, then I still wait for the dwgs of the gardens and the other 2 buildings, but I also did plan 8 with the cover that ends the 3d model:
the images were attached (as always....) to make them "readable" and only by those who lodge.
I also deleted the request for "contacts": who is interested in advertising can ask directly to the administrator or read here:http://www.cad3d.it/forum1/showthread.php?t=2945or write on the moderate section: job searchhttp://www.cad3d.it/forum1/forumdisplay.php?f=29Thank you.
Okay, thank you, as soon as I have time, I'll post the building and the first renderings.
update: I joined the building, now I wait for the revision of the architects, I still have to join the various plans and make the colored plaster (the building will have various colors)
After that I have to make the other 2 buildings, one is the same mirrored and the other is the same without a plan, then I have to do the gardens, someone has pots of flowers??? where can I find them?? something not too heavy.
I've joined the building, I have a very serious problem! I throw the rendering, but as part it begins to calculate but no image comes out! I've let it calculate even for 2 hours! in 3 years I do this job never happened to me!
I add that 3dstudio unfolds, when I interrupt the rendering he continues to calculate, does not close 3dstudio, does not turn off the pc! I have to turn it off from the button.
update: I tried to make it on my old pc, does not make it! plant in building light cache, use only 20% of the cpu that nerves! I also tried to import solids into a scene, as the amount does not make it anymore, it always plant in the calculation of the light cache but why???equa I have removed all the superfluous, away the 2d dwg, away the weed!
95 out of 100 is a problem of lights.
turn them off and put one simple. If you don't mind, delete the lights and do it again.
problems so I had 3ds, alias, maya, any program, if the lights begin to reflect each other is the end.
Unfortunately it is not a problem of lights!!! I only have the sun!:mad: and I can't take it away, I think I will do it again from scratch: mad:
you can try so... it's a binary search method that I read
open a new file
file-merge and select the file that does not work
selections half the elements
try to make a render
if it does not work selections half of those before and try to make a render...cosis below until you find the element that creates problems
open a new file
Yes, in this way minimize the number of tests, always halving the set that does not work.
Are you sure you don't have forgotten lights around?
open a new file
great! I solved!! were the railings that made 3dstudio plant!! <
I got a new scene. I imported the blocks (die, ends ecc.) one by one and every time I rendered arrived at the cursed railing railings I noticed that it was stacked in renderings.
place a first proof rendering, now I have to remake all railings, I try with railing, if you plant still polygon lighthouses (a nice cock)
Where can I find them?
I have a problem with shadows, I am too dark !!!:Mad:place also the parameters of global switches
I had to wait for the architect to overhaul the project, then I had more to do, finally I could go ahead, unfortunately the renderings were planting!! I found that the railings made with railing made to plant the renderings, so I had to cancel all and give them back from scratch with the boxes, a unique ball! For these changes I lost one day!!
Can I please say something? I know that as a good engineer I can't comment on the aesthetics, but that wood on the outside of a palace is a horrible thing!
Is that an idea of the architect?
near my house there is a building whose exterior is all tiled with brown, I get nausea every time I pass in front of us.. .
