wall mounted on curve
  • Thread starter Thread starter larchitettol
larchitettol
use revit 2013
I am trying to figure out how to make a roof trim with profiles that follow a curve, instead I can only set them as vertical or horizontal or with a choice angle... I would instead place them out orthogonally from a curve.
Is it possible?
Not really... I have two curved lines like the rails of a track and I want the climbers like the crosses i.e. aligned with the curve
I have to place the climbers like the crosses of this track
I don't think so. in my case the curves are both on the same floor and the pillars that connect them are not parallel to each other
Besides, even if I don't need it in this case, I don't even know how you did give it to the Kurdish mountaineers.
that with the continuous facade command (at least for me) can not do so, I used the railing command
I attach to them, of course, dimensions and names are to be redefined
I used the command line > start-end-route
Anyway, with the railing for my case, it's not good. even if I have to make curved climbers in the plant I use your system but in my case it is a tilted roof that has a curved perimeter of which I have to make an ornament with the beams that follow one of the curves of the edge of the roof
not knowing how the roof is made I can tell you to try to select as a support host of the balustrade the roof layer and then select the roof edge to define the curve line, see if it works
with the roof does not work but with the insole of the floor you, you can
Something like that?
with the ground is only sloped
insert a tilted plane equal to the slope of the ground
draws curved beams and changes the beam host to the tilted plane
draws straight beams on the sloped plane
the position should be handled with offsets
