wall-setting stratigraphy
  • Thread starter Thread starter s.rostagno
s.rostagno
Good morning to all,
in revit I need to manage the individual layers of the external walls, for this reason I use the command manage stratigraphy.
the problem is found in the changing of the layers in the presence of the locks. if I put the stratigraphy in the wall when I insert the lock the layers turn back correctly. but when I explode the stratigraphy, the turns are lost, which I can display exclusively by setting in stratigraphy visibility, original exhibition. I can manually recreate the turns, but doing so if I then move the lock I lose manual changes.
are there solutions to automatically get the twists in the exploded stratigraphy?
steak
not that I know. but when you say you have "the need to manage the individual layers of the external walls", what do you mean?
for external walls I use the exploded stratigraphy, as by command divides layer and excludes I create all the voids to accommodate pillars or systemic caves in the walls, moreover it is useful to simplify the realization of the nodes by extending some layers.
