wall-vetrat transplant in 2013 rev
  • Thread starter Thread starter fraco92
fraco92
Hello everyone! I’m finding a problem in the 2013 version of revit (I didn’t have this problem in the 2012 version). in the 3d view the walls leave the windows in transparency. I attached a screen image to make you better understand the problem. I would like to eliminate this transparency which is very annoying. I hope you can help me! !
install the service pack, if you have not already done so, check the hardware acceleration settings and update the video drivers. What video card do you have?
what settings should I check/change more precisely? the service pack where I find it or which version would be exactly? my video card is a nvidia geforce gt 330m.
options> graphics
the service pack find it on the autodesk website
You know how to get there, I didn't know what parameters I should set. I believe that I have solved the problem by disabling hardware acceleration.. and not even reactivating acceleration. It's a mystery!! :eek::eek:
it was a ver. 2013, issue that appeared when files were opened with previous versions.
the service pack has solved everything.
if instead it was a card problem, always on the autodesk site, there is the list of tested cards and those "supported"
