Cathrine
Hello everyone, I just signed up for this forum. I'm an aerospace engineering student. I am finding some problems in the resolution of a project. I try to explain it in a short time.
I must carry out the analysis of warping and shear lag of a fuselage section stiffened with currents. (all this using patran/nastran)
questions:
1) I create the fuselage as a "solid" entity and the 4 currents as "curve". when I make the mesh is enough meshare only the cylinder or do I have to remake the operation even for the 4 currents? If so, how do you do it? or better, the mesh of the cylinder comes out thickened and given by elements that seem triangular (tetrahedral?), so with what criterion should I then meshare the currents?
2) to observe the exit of the section I have to apply a torque moment. At first I tried to bind one end of the cylinder and to apply one moment at the other end. In the second case I applied a pair of torque moments equal but opposite to the two ends. When, however, I go to do linear static analysis nothing happens! What do I mean? Going to analyze the f06 is as if no time was applied and then in the "results" section of the patran nothing comes out! then maybe I was wrong to apply the twisting moment? my procedure is: loads/bc - create - force - nodal - new set name - input data - force < 0 0 0> - moment <40000 0 0 > (e.g.) - ok - select application region - geometry - select curve/edge and I go to select one of the two faces of my cable cylinder - ok - apply
the moment is then applied to me on a point of the circular crown ( cylinder side) is there something wrong in this process? Maybe I'm wrong with the point where I hang the torque moment? I was also told to apply it along the cylinder axis, but how do you do it? The axis is not an entity you see. Do I have to draw two points that match the centers of the two sides of the cylinder? please help me...... there is something that I miss on the application of this moment :36_1_4:
3) question of curiosity: I remember that there is a command somewhere in the patran that allows me to choose what things I want to see at the end of my analysis as efforts, deformation, tension etc...... but I do not remember how it is done. Can someone refresh my memory?
I hope someone knows how to solve these my dilemmas especially the second because I tried to search everywhere maybe taking even a simpler structure such as a beam and applying a torque moment, but when I carry out the analysis and "attack" the results do not come out to me as if the analysis did not just make it... .
I look forward to your opinions.
thanks in advance
questions:
thanks in advance
