hello to all, I am doing a set where I would like to bind the washer, as from attached photo, until it collides with the tilted sheet.
Can you tell me how I can do this? thanks to all
- put the axis bond on axis between the washer and thread so that it can slide by hand
- enable the contact resolver between the washer and sloping top
- drag the washer slowly until it touches the sloped plane
- put the face-to-face constraint with the vertical plane, letting the box close to the glasses pop out (in the bond window) offset estimate.
remove the contact solver and the washer is in place
