water swimming pool
  • Thread starter Thread starter marco.bre
I have a problem: I created a small pool full of water and in the preview it comes out correct (as I would like) but then rendering the water practically you do not see. I don't know what to do anymore. Do you have any advice?
I did a test.
in a pool I put a solid giving it water->pool material 140 cm, 315-35 or 65 is the inclination of the sun
I then modified the height of the solid bringing it from 0-140 to 139-140 therefore a cm thick.
the result is this
the person in rpc was put to see the refraction of the diversity of water thickness
Can it be a mistake to create a floor whose only material is water? because I don't know what to do anymore. It's like water's too transparent. .
try remaking water as solid, you can vary the thickness more easily and see with which thickness the result you like most
I'm beginning to go crazy ahahah excuses ignorance how to create solid? I have always edited existing masses (such as floors or other)
Sorry the double post however I solved for the solid but always remains too transparent.. Can someone tell me that transparency use for water material? Maybe that's what I'm doing. .
it must be taken into account that a swimming pool fills it with water network water and must be by force without suspended substances as it can be a lake or river and therefore transparent
I made a further test with thickness of solid water at 70 cm and 100 cm
and then one with camera height 170 cm from water fur
I add this aerial photo to demonstrate the transparency of the water of a pool, notice the shadows of the edges on the pool bottom
