weight measurement unit distinct materials
  • Thread starter Thread starter Roby-iso75
Roby-iso75
Good morning.
in a combination of use parts that have different weight units (kg and gr).when I insert the distinct materials the data that I read in the weight column mirrors the value expressed in the unit of the relative part. is it possible to choose the weight column unit so that it automatically converts all values into one homogeneous measuring unit?
change the design environment unit
thanks for the answer, however it does not affect the value read both in the cartiglio, and in the distinct materials.
to me it seems that the unit of measurement of the part or the axieme to which they refer is "hereditated". I attach an image to specify:
the cartiglio expresses the correct weight in kg (such as the axieme to which it refers)
the distinct weight is expressed according to the part (if it is in grams or kg)UNIT_MISURA.webp
Look, I've made a pair of four cubes equal, changing to each one the measuring unit.
I made the design with the distinct materials and the value is always the same and follows the unit of measurement of the design.
did you do a ctrl+q to update the file?
Assieme1.webpI have done the same test, actually as you say the distinct and the cartilage perfectly follows the unit of measurement of the drawing sheet (kg, gr , pounds, etc.. )
Therefore, returning to my first image, it remains to be understood as never by changing the udm of the design part 1 and 2 do not update, while part 3 and the cartilage are updated.
the 3 parts were made in the same period and are updated to the vers. 2019 sp2.
could have been created on 2 different systems perhaps with different templates, there might be some "flag" to be activated hidden in the settings of the document. . .
I attach myself to this discussion, I need to put in kili the weight of the pieces and not in grams. it makes me change it to the document measurement unit but I would like to set it in the default measurement units, otherwise I have to change it by hand every time... Can you?
you must set it in the part/axieme model.
so when you create a new part/assieme, it has default
