weirdness with island layer command components in a set
  • Thread starter Thread starter MORENO100
MORENO100
in a combination I created a layer "pippo" where I included some components, now if I select it and start the command "isola", the program shows me in the graphics area only the components I had included in the layer excluding all the others.
until here everything ok, but the strangeness I detect is that if I make a usual double click on a feature to view the sketch odds, the odds appear but are not selectable! and how do I edit them from the graphic area?
Can you help me? Does it happen to you? Thank you.
p.s. use creo 2.0 m250
I press that I don't use layers to throw you in the parts together, but I think it's still not the right way to act to do these things.
use the representations, certainly in addition to working well, you will have much more manageability of the versions, than with the layers.
ok thanks to the indication, could you still try to see if even from you my own strangeness with the layers? Maybe it's due to one I don't know what setting in the config, or depends on an error in my release. Thank you.
I think the representations are more useful, but apart from that, did you try to activate the component you need to change, if it does the same trick?
I tried as you described and did not give me these problems, even not activating the parts but only going to redefine the feature from the part model tree in the axieme.
I have no idea what that could be.
Try to see if using the representations gives you the same problem.
great, on what version of program and release did you test?
the representations I have already taken in considerations but for the function that I intend to carry out present some "inconvenience" that by their nature or by my ignorance do not satisfy me.
Perhaps in another post I will ask you more specific advice on representations ^^^.
in the meantime, thank you all for everything.
I believe 2
m220
