welded edge
  • Thread starter Thread starter volaff
volaff
Bye, guys.
I realized the attached sheet that, in fact, should be welded where I inserted the welded edge.
In summary, I do not know if the mode of representation is correct (in 3d the welding seems to me "burnt") or it is advisable to make only a table indicating the size and shape of the welding cord.
Excuse the doubt.
a warm greeting.
fly
in the table you must necessarily indicate the welding if this is to be done. the worker must neither invent nor imagine anything.
then you can well leave the edge without welding and insert a final treatment annotation on the table
or bring the game of the edge-flangia function to 0.01 and have no brute (to be noticed that in the table is not represented as welding but as continuity of the sheet)
for welding indications is a normal angle welding.
whether to insert or not the specifications of the welding, as well as to represent it in the table, depends on the directives of the technical office (which seems to me is teaching you quite little)
