welding configurations
  • Thread starter Thread starter cimaguy
cimaguy
I would like to know if you can create configurations using the structural profiles: I would like to create a file with inside the 3 versions of the frame (see image) but I can't configure the various versions.thanks
in 2019, I don't know what version you have, you can't manage the groups and components contained in them in the property manager welds.
based on what is the result you can act with multiple welding functions and short/extended function and delete bodies
for example, but the image does not clarify how they are made of the inks, you could make the 3 frame version and then with 2 functions delete body eliminate excess traverses
I have 2020.but if I use the method of clearing the bodies, can I create a configuration? what I would like is to put the component in a set with the three versions, and to be able to choose which of the three uses
ho la 2020
insert it into the profile so you avoid asking it every time.
configurations can be created in any context.
your scheme will be as follows:
basic configuration with frame 3
Frame 2 configuration with lower cross body delete function
Frame 1 configuration with the delete body function of the remaining transverses.
this is a method; If for the fixing of the crosses there were inks but it would not be good. there is no single scheme, but always according to the result to be obtained
I did not manage to create configurations.I preferred, seen that the measurements change me continuously, create a parametrised base structure and insert, from time to time, the transversal elements that are required to me
I find it uncomfortable to manage the elements of recess and fixing between the various elements.
working in the custom-made furniture industry,the joint elements and the measurements of the frames themselves change continuously.in the company now I am working with the swood application,which allows to manage these situations in a parametric way
