welding representation
  • Thread starter Thread starter fall942
fall942
Good morning to all,
Excuse me if the questions are trivial.
I wanted to ask if someone knows if there are functions in inventor to represent welding cords on the 2d drawings (put on the table) and how to use them
in solidworks there is a function that allows us to do extrusion with offset or cut extrusion with offset. Does anyone know if they exist in inventor and where they are?
thanks in advance
If I understood correctly you would like to make welds on the solid and then see them when you do the untouching.
If so welds can only be done in a welding assembly by double-clicking in the browswer.
when you make the table you only see lines (if it is not a section) and you can use the milleped command to represent welding
I hope I've been helpful
Thanks for the answer, I really wanted to.
I use inventor 2018, but in the table I cannot represent the welding cords i.e. when I have to represent a welding that must have a certain length .
