Good morning.
I just started using welds to build an attached carpentry structure.
I would need to know if the implementation procedure is correct and if there is a faster method. Thank you.
As far as I am concerned, it is correct.
The only thing I could do to you (but we're at the total paranoia is that you could manage with a single 3d sketch, without needing to do first the one for the plant, then the one for the height.
