Bernoulli
Hello guys, I should check a weld between plates and a profile. Welding develops in 3 sizes and therefore I do not only have a xy plan. I have established a terna of xyz axes, I have established the coordinates of the baricentres of the various strings regarding the system and subsequently I calculated the center of the complex. What do you recommend doing? consider stresses in xy and yz plans? I have the doubt that it does not work because the rectangle I can consider it slowly in a view but in the other orthogonal view the same rectangle (which represents the cord) becomes a line! otherwise I should consider it throughout its area also in the other view... I hope I explained. Thank you very much in advance! !
