wf3 - modifiche family table con open office
  • Thread starter Thread starter Giovanbattista
Giovanbattista
good morning to all, I write (after 2 years) in the sub-forum "configuration" because the question is generic, not linked to specific problems of modeling, and... maybe solved with some setting of the config or windows :confused:
is it possible to change the family table with open office calc, instead of with excel?on my office station is installed only open office, and of course when I click on the icon "modifies current table with excel" nothing happens...I saw looking with google a similar problem of people who have office 2010, but without answer. .
young man
found the usual sad but effective system to bypass the problem:
- export the family table in "text" mode
- edit to pleasure with note block the .ptd file
- re-import the file
Obviously it is a reasonable system only for simple family tables...but it is a start.
someone with wf4, wf5 or creo has already verified whether the compatibility problem persists or is there no longer?
ot: hello young man... all right? I see that you always continue with proe:smile:
I go to memory.. try this way:
in the config.pro set:
part_table_editor = editor
pro_editor_command = full launch path of openoffice scalc.exe.
save and close and restart
Let me know.
Ozzy
hi ozzy, thanks for the suggestion.
Unfortunately it does not work: I set the first parameter on "editor", but then for the second parameter the path "c:\programs\openoffice.org 3\program\scalc.exe" does not give signs of life. Obviously I tested the path even with explores resources, and it is correct.
thanks to the same :frown: I will try to clench deeper with the voices of the config, maybe we are close to the truth :rolleyes:
young man
I have the same problem. .
at first I thought the problem was with the path "c:\program files (x86)\libreoffice 3.5\program\scalc.exe" because it has the spaces but I made all the combinations with "part_table_editor" and "pro_editor_command" but calc never leaves :frown:
