wf4 fem lite earchsi amuita
  • Thread starter Thread starter SweptBlend
SweptBlend
fem/gurus,
I have a very small problem,
I modeled for demonstration this zipper,
assigned materials/loads/ constraints/ and mesh...
And then?
my fem analysis panel is "hardened", yours?
How do I do an analysis?
to know if it breaks or not? to shoot an analysis video? html of the report ?
I need to install more software, wasn't there a lite fem license on wf4?
I will be full of gratitude for all those who will help me... ;-)
What makes me think is that you write that you have done mesh too!
in fact in previous versions of wf4 (and I also believe wf4), you can:
- set what you set up and export the model to a fem program
- set material loads and constraints, choose the type of analysis, display (deformed or not and with what scale of deformation, display " fringes", etc.) and make the analysis to pro/mechanica which will use its automatic mesh
Herbie.. What makes you think?
who even managed to get there?...?? :mad:
:redface:
Okay, but how do I get to the bottom?
Is there any soul that is not already in vacation?...
Help!
from me the analysis panel works in wf4, but I have the promechanica license, the only doubt I have is that while working in promechanica the server gives me the license available.
Cingolo,
if you can post analysis performed, avi, and html,
I propose aperititivo da dolcelucia....:biggrin:
that I could even get there?...? ? ?
absolutely not! It makes me think because one of the first times that I "fighted" in pro/mechanics, I made the mistake of creating mesh and then I couldn't do the analysis because pro/m uses its automatic mesh.
if I have a second try to give the procedure
then ..you have your model (remember I use 2000i2 and I have no way to check on wf but I think it is big way the same)
from applications - mechanica.
deselect fem mode
choose for example structure
under model set material constraints and loads
under annalisys impose the type of analysis, breaking criteria, etc.
then run
then results
and in the settings of the window that displays the stress-based piece imposes the display type (fringe - or color variants according to the load or deformation) and impose the deformed display.
I hope you've been helped
Maybe it's a build thing.
I heard that fem lite will be available for all versions of wf5 while for wf4 only from a certain build on (I don't remember if from m060 or m070).
check with your dealer, you should know the details.
mechanica lite is available free of charge from pro-e wildfire 4.0 m070, you have to cmq get regenerated licenses.
Bye.
Hello everyone
I installed the m090, actually there is mechanica lite required as an option when you launch mechanica. However, there is the limit of 200 surfaces of the model to be analyzed.
