wf4-problema pattern table
  • Thread starter Thread starter ipstatico
ipstatico
Hello.
I have an annoying prolema. when I try to run the pattern table does not open the notepad window. What can be the problem?
thanks to who will want to answer
Excuse me but, I use the Italian version, do you refer to the table-guided series?
Yes, yes. Can it be a privilege problem? I installed win7. the original is in German, then I installed the package for the Italian language
Can no one help me?
probably try to open something else, try to set this option in the config.pro:
pro_editor_command and how value you set the path to the exe file of notepad, if you have win7 should be:
c:\windows\system32\notepad.exe
save config.pro close and try to see if it works, otherwise you impose it as another editor, protab or excel.
I've already tried and it doesn't seem to work. I'll try with other publishers and then I'll let you know. Thank you!
tried with other editors (protab and excel ma nada). proe editor doesn't even work if I go to select it or at least, I click and he opens and closes in an instant
I tried on another computer: if I click on protab.bat the window opens and remains open. at this point can be a compatibility problem between win7 and .bat file? or privileges? How could I solve the problem? thank you to those who want to answer me. Hi.
Could be... Are both versions of pro/e wf4 equal? same datecode?
the datacode is the m190
at this point the field is tightened... wf4 is fully supported by the m150 forward for seven, it could also be a "bug" of the datecode, try to create a new profile in seven and see if it works, if you are administrator of the pc I don't think it is a question of rights, even because it only opens a program, nom goes to write anywhere.
I'm running. on the pc win7 the datecode is m040
then it can just be that the problem is related to that as mentioned above, you must download and install at least the m150 or later we are currently at m220.
upgraded to the m200 version but still not working.:frown: I will try making a new profile but I think it will not work. But what can be?
if even in the other pc where you use windows xp 64 bit the starting configuration is the same, I doubt that it is something inherent to the config.pro.
Didn't I ask you if you even tried to get it started with default configuration?
is identical because there is a batch file that loads from local servers on pcs the same config.pro and all the rest. the default config where the recovery?
