Parametric_Ozzy
If you have a batch, you should go to the proe/bin installation folder and launch proe.exe, first though you should temporarily move or rename the proe.bat, otherwise you charge it every time.is identical because there is a batch file that loads from local servers on pcs the same config.pro and all the rest. the default config where the recovery?
