ansyolitico
I have a little problem that I can't understand why
I have a vertically mounted ball recirculation screw that moves a weight of about 1800 kg , the weight is supported by a plate bound by 4 linear skates on two parallel linear guides between them... the snail makes strength on a frame bound on the plate but moved by tot cm from its half-work (in the center you can not put). the screw is inserted in a gearbox located at its extreme high.
between the reducer and the bolt there is the support structure of the screw so configured (from the top down):
wreath with grain
2500 kg axial bearing
support
Conical roller bearing inserted in the cast made in the support
screw shouldering that goes in line with the inner ring of the conical roller bearing
the surface of the support that goes in support with the axial bearing is not worked, but simple left raw, being the crude a drawn.(I think here is the first big mistake)
now with a operation of 200 cycles per day on a time of about 3 months that wreath tends to unscrew.
I assume that the axial bearing blocks (grip) and avoid the wreath just at a time... .
What do you think?
wreath with grain
support
What do you think?
