brienza
is it possible to have the wheel command for example by pressing the mouse wheel...or some convenient combination type ctrl+rotellina for having the wheel command?
f4 + rotellina as it has always been since ancient times. if you didn't change the quick assignment, by default it is so.is it possible to have the wheel command for example by pressing the mouse wheel...or some convenient combination type ctrl+rotellina for having the wheel command?
To say it all seems to me it is suff to press f4...but I would like to press the mouse wheel rather than the ephequattro...!thank you!f4 + rotellina as it has always been since ancient times. if you didn't change the quick assignment, by default it is so.
it's the same thing, f4 or shift+terzo mouse button (or press wheel) give the same result, clearly if the central key is set by central key!To say it all seems to me it is suff to press f4...but I would like to press the mouse wheel rather than the ephequattro...!thank you!
If I press shift+rotellina activates the pan... I would like to change the setting and make it turn.. but I don't know how to do it!it's the same thing, f4 or shift+terzo mouse button (or press wheel) give the same result, clearly if the central key is set by central key!
Try to cuff with the mouse drivers, I don't think it's due to inventor, if so would you let me know how to change the settings that I have in mind a couple of thingsIf I press shift+rotellina activates the pan... I would like to change the setting and make it turn.. but I don't know how to do it!
Honestly, I don't understand it.who knows if in the future there will be a forum where those who have nothing to say can not say anything...![]()
to me it seems that it means:Honestly, I don't understand it.
