:redface:Hello everyone.. .
I refer to the attached image; I would like to print the milu writing in white above the gray sampling (I gave white to the text color) but previewed me it black... .
in theory a "region" (annota>region) must be made to which to assign the gray color (and solid remnants).
on the same a text, to which to assign the transparent background, and the color of the white text .... but precisely (unfortunately) in the printing phase is black (?)
solution:
import a dwg block already "prepacked" ... according to your needs ...
Yes, I have done so;
But if I do a dwg block in the same way, I mean by white text would I print it white?
and if I did it with an image, would it be better?
Thank you very much
