why is it wrong?
  • Thread starter Thread starter andr34
andr34
hi to everyone, I am following a simple tutorial of inventor 2018, I don't understand why with my model I can't apply the bevel. the solid on which I want to put a bevel of 2mm is a single solid derived from the union of two solids but now it is unique.
This is a screeshoot from the tutorial to show you how it should come:
sketch 2 is without quotas, probably the error is there.
if you impose the bevel to 0.6 does it, beyond it is unrealizable.
thanks a thousand techno, I confirm with 0.6mm no problem, however regardless of the odds in the sketch 2.
do you mean that binding or listing the sketch can affect the success of the bevel?
no, the bevel succeeds if geometry allows it.
in that solid you have dimensions that allow a bevel to a maximum of 0.6.
Constraint and quota discourse is only the right method x to work.
If you want a stable model each sketch must be completely bound.
and it's just the beginning...
hello to everyone I am new and I don't know who to ask, practically I use creo 2.0 and I have a problem with a design, open the step file and geometry is open in some points and I can't close it...how should I do?
robert tutu, you have asked a question not relevant with the section, there is the specific section of creo, and also in the tail to a discussion that treats a very specific topic and far light years from your problem.
