window with tilted face
  • Thread starter Thread starter bagiolino
bagiolino
Good morning to all,
Would anyone explain to me how to create a window with a tilted face? ?
all default windows are rectangular or square, but if I wanted to insert a triangular or trapezoidal lock into the project? ?
I tried to create a new family using "meter window" but I can't give a tilt parameter to the top floor!
I also tried to create a vacuum but when I cut geometry tells me that a family cannot have an opening and a cut in the same host!
Maybe I have to choose another kind of family? ? ?
In general the argument has already been dealt with in other discussions with the name "sguinci".
a window with sguinci is present in the forum of families and objects
perhaps I have explained badly, I did not speak of sguinci but of the little face (or better, the upper part of the window).
In practice I wanted to know which family to choose and have advice to shape a lock that seen in prospectus is triangular or trapezoidal.
before creating the discussion I looked in the forum but I did not find a similar topic. . .
hi, you have to start from a window-based family, then delete the vacuum that was created with 'open cutting' and create an ad hoc vacuum that you manage with the reference plans.
in the example the vacuum with triangular face is controlled by the arrow size, but you can handle it as you like.
thank you frcprogetti! !
I had tried to erase the void but without success. I probably had wrongly selected the box. I created the window using a wall-based family!
the problem is that revit now sees me as a component and not as a window... That's good for now!
Hello, everyone.
a question: once you create the opening on the wall, with a random form, how do I put a lock on it?
is it possible to create a free geometry opening and make sure that the lock is inserted automatically?
Thank you very much
Ni!
if the shape is really random you can not do.
if the shape is parameterizable just nest a family tightening.
Obviously the parameters of the main family and the secondary family must correspond.
Bye.
