wireframe-ridurre linee
  • Thread starter Thread starter spilladabalia
spilladabalia
Hello everyone, I need help.
I have stacks that I intend to display in wireframe in my rendering, they are simple cylinders imported from autocad to 3ds 2009. I attributed to the pillars the wireframe material, but the cylinder generators are too many and therefore the effect is lost completely, they seem full for the lining of the lines. Can I intervene somehow? Can I do it in 3ds or should I return to the autocad model? Thank you in advance!
hello, convert the pillars into poly and apply the "optimize" modifier, or manually clean them. Moreover if it is simple geometries like a cylinder you should remodel them directly in 3dsmax
Could you post the renderings?? so we can advise you. :finger:
