without comments.... .
cacciatorino
Sometimes the sadism of the programmers reaches inarrival tips... .
"Impossible to load the axieme" because it doesn't find a file. but, if you just don't want to do as solid edge or solidworks that charge me the axieme even if they lack files, at least tell me which file you can't load!
Immagine.webpand of course these things always when you have a meeting with the client in two hours... .
Good morning
If it's like it happened to me there's a string to write that restores me had said it er president only that I don't remember it, I have to look if I find it on the pc, once I think I've found it on the help only to tell you where...... I know that I'm not very helpful but I repeat if something happened to me you can save see if I find something
Good morning
No, but I recovered from the car, there was almost everything.
I just wanted to highlight how sometimes programming is so badly done to create huge problems to the user, and only for simple neglect.
I thank Mr President for the help.
if, at just failed loading, we write in the command line:
Code:
(display (cluster-manager-errors))
the system returns the id_model of the part/assieme that could not load. with the advanced search of model managers you can then trace back to the model name, and then possibly to isolate the problem.
Code:
I am pleased to be still useful despite the "rust" :cool:
I sneak into the discussion to ask you which version you have of creo modeling and if you tried the release 18.
I have the 17th and I should pass by the 18th.
I saw that it has totally different interface, ribbon style like word.
in version 15 there was the possibility to load the axieme even if it loses some files, after 15 they did so that this possibility remains but at a fee. objectively it is a porcade this. If you need on the American forum of cocreate search "error 337" and find everything, wait for me to have the pc under hand :)
Thank you so much!
Unfortunately when you have to deal with people who are "limited" mentally and negatively sees a "new" is difficult to digest the ribbon menu.
thanks to these people we have the version 18 paid but still not installed.
Are you sure this is the command?
This morning (of course I have to be with the customer in an hour) the loading failed again. the command provides me with a list of id_models which, however, taken individually, charge everyone.
upload them before loading the assist, should share them without looking for them on the file system.
