work plan inventor
  • Thread starter Thread starter fibonacci
fibonacci
inventor. When I create a work plan how do I display intersection points with a perpendicular surface on the floor?
or, if the plane is parallel to a surface but rialted compared to it how do I view the points below?
if what you want is similar to what you see in the attached pdf then the solution is:
made the plan in the location that interests you, walk in sketch mode and project the "cut edges ", command that you find in the drop-down menu that appears as an alternative to " project geometry ".
Bye.
ps. : do not ask the same question in mp, the forum and its issues are public.
Okay, it works, but can't you locate the intersection points with the plan automatically as in solid edge?
Good morning
I'm sorry if I interfere with cutting edges like we do to eliminate them, I can't find any geometries anymore.
Excuse me again
Good morning
Excuse me again
Have you tried to edit the sketch, and then interrupt link?
