working on sections
  • Thread starter Thread starter iron72
iron72
Hello.
I created a sketch and extinguished it with the surfaces.
I dissected it in three sections, in the product environment, and now I would like to change the profile in those three sections.
How is it better to work? move the reference plan on those sections with an offset then enter sketch mode? or is there any other way to change the profile?
you can copy and paste the sketch you created
in the plans where you want to change the profile, then vary the
quotas, directly in the sketch;
or , using adjust sweep and position the sketch
where you want along a dorsal. .
or make a blend in mod. point, in tang. etc etc
opure a multisection. ...
depends on what kind of surface you want to get-
other possibility is to use parameters and relationships from
apply to sketches and path to "automate "
result-
to the
request similar to what I did qui and to whom he always answered the same:)
alpole can't open your file, did you use a post v5r19 version?
