workset
  • Thread starter Thread starter larchitettol
larchitettol
revit 2013
I mistakenly created a workset on a file that I didn't want to use as such... now I am not going back indeterminate.. .
suggestions?
see illustration (English) :
file> open find the file. then, the option of "detach from center) will be at the bottom of the window.
clarification. if you want to say only 1 workset, use "cancella", as you see in the image in this messaging.
if you want to turn off or remove all the worsets in a file, use the method I described before.
