workstation per inventor
  • Thread starter Thread starter Beppe
I don't understand that means it's better to take a 1700 than a 3500?
also with a fx1700 or fx3800 6gb ram are good or you have to increase accordingly
better take a fx580 rather than fx1700 :tongue:
In practice it is precisely so... except for very special cases, the performance between a model and its subsequent coarse lower band are comparable (but not the prices that never undergo proportional decreases). .
the nvs frameworks are born for the 2d... let them lose. . .
will also be sufficent 6gb, but to me the 4gb I currently use are tight and almost step to the 8gb... in any case, buy ram counters in 3x2gb modules, so they leave free 3 slots for the eventual passage to 12gb...
Just like giga says. It is likely that a 1800 has superior or equal performance to a 3700, but I have never seen comparative tests between the two and I cannot confirm it.
One last thing for now, I'm going to go through the purchase:-) I own a bhroter 960 laser printer (I hope I've written the right brand) purchased about 8 years ago it doesn't have the usb attack so I couldn't use it so I've been told. Is it true that the format is only a4 I'd hate to put it in the cellar there is any device on the market that you help me in this issue? or did I not understand anything?? Thank you.
One last thing for now, then I'll go to the purchase, I own a bhroter 960 laser printer. .
a printer port should always be there, in any case there are cables from parallel to usb to about 15 / 25 heuri.
I apologize last doubt about the processor:
I've just been offered " xeon w3520" I mean with this kind of processor if I want to put a fx3800 the processor is overrated?
If not I put a fx1800 spend less and I have the same result.
What's the relationship between the video card and the processor there are also the w55s... I think and they cost too much maybe to me....
...and good day
...and good day
I have seen evidence of the fx 580, 1800, 3800, 4800, 5800 in comparison with tests related to inventor and pro wf4.
First of all I wanted to say that the fx 580 goes like the old 1700s and 3700s that cost a sproposito, while the 580 finds it on planet hardware to 180 heuri ivata!!!
the above mentioned series goes more because they exploit the pci-express 2.0 which has the double bandwidth compared to the previous fx x7xx series.
therefore between processor and graphics card there is a better data exchange in favor of final performance to video.
know that the proceeding w3520 is enough to saturate the pci-e band even if it is at 2.66 ghz (then in turbo mode comes almost to 3 ghz).
I would say however not to go beyond the w3550 which is a 3.06 ghz also because then it is only money spent extra to have some tenth point in the tests!
then, surprise of surprises discover that between 580 and 1800 you have performance advantages, but between 1800 and 3800 ...4800 or 5800 ....no! !
then the fastest machine in inventor, tested between various brands and models was a hp z400 with the w3540 (2.98 ghz) and the fx1800...that I leave to those with double xeon e5530!! and the fx4800!!
then, if you don't have to make assembling with more than 25000 parts stopped as well at fx1800 and the money you save on the card (about 500 euros) invest them in ram that is better and arrives at 12 gb. With a car like this, go ahead 6 years before you realize it's slow. but then the new directx 11 cards and g300 graphics chips will come out and maybe with 200 euros you will take a new card with 1 gb of ram and better lenders of the fx3800.
in the computer world you have to spend up to the amount in which you get concrete advantages, then stop, because after 1 year you will spend less getting more..... if you then have other needs ... then the speech falls from itself.
as an example here is the link
http: //www.tomheadware.com/it/char...t/spepc-viewperf-10.0-pro-engineer, 132.h tml
http: //www.tomcardware.com/it/chart...ineer, 132.h tml
I followed the advice, ordered a processor w3520 with fx1800 card
and I brought to 12gb of ram I was tempted to take processor w3540 I cost a little.....va bhe (I can always rethink .....:smile:) anyway thanks for now of the councils I hope to return one day
I am finally in possession of my unique workstation difference they have installed me
the motherboard an asus p6t ws professional .
and later I will update to seven free (we hope)
I have a problem with device doesn't recognize it can't find drivers for 64bt I think I have to change scanners?
I'd like to know if I put in my old autocad lt2400 and don't recognize it (so they told me and I'm afraid to try it, there's no chance to make it work at 64?)
for the scanner you have to find the correct drivers, if it is outdated and there are no aim is you have to replace it. before you get a new one, make sure all the drivers are there.
if autocad does not work you can try to force compatibility as you do with 32-bit xp.
I'm sorry I lost the discussion, I tried to install it autocad lt2004 I came for the truth to insert the serial number of the CD, then I went out for fear of some casino, however I can't force the compatibilty' I'm sorry.
If Ilario says you can't (this saddens me a little)
I wanted to ask from the nvidia site I see that you can download specific drivers (autocad etc...etc.) do not see inventor that I do not unload any drivers? My card is picture fx1800
I would like to know is translated into Italian the pages of the site mentioned above?
