worm gear and dynamic simulation
  • Thread starter Thread starter enrico1979
enrico1979
Hey, everybody.
I come from the world of pro and but shortly I will pass to use inventor (the real 2013).
I am therefore practicing with the software to avoid being in trouble as soon as the passage from pro and is completed.
So if someone can tell me which input is in the joint>worm gear insert menu of the pitch, also because by going to select right-click, in the right-click menu where the features are listed, the one related to the newly created joint and selectndio properties appears a menu where the parameters window shows under kinematics screw pitch and wheel radius and the input of the screw pitch goes to coincide with that of the pitch mentioned above.
to make it short I have to insert the diameter (or what else) of the screw?
to I also wanted to say cmq that inserting the diameter happens that the gear is not accurate (the teeth internetrate) what would make me think of input errors to attribute to that pitch.
hoped that it was not too confusing and waiting for delucidazioni from those who know more than I wish
Good job
