written captions for holes
  • Thread starter Thread starter romy
romy
Hello everyone,
Is it possible to change the character set by solidworks for holes captions?
as from image attached I would like to be able to change the writing "passante" all capital in "passante"
I searched in the callout file but I can't find it
absolutely from the properties of the document. Once you have settled all the properties, you can also save yourself a file of "styles" so you keep everything saved, or even have multiple files with different styles. you can associate the various styles to different initial templates.
attention that styles are in the document property tab --> standard design (until the end of expandable menus. all the other options there are, are solidworks in general.
Good morning.
I knew this but I don't find how to change from "passante" all in capital to "passante" with only the first capital
You could hand it over. You also need to understand what variables indicate. But I realize that this is a piece, because it makes no sense to do it by hand for every caption.
I always put everything in the drawings, that the tiny certain workers begin to blaspheme ahaha
I tried in the callout.txt file to see if the description in Italian.... but there is really no
I think it's an internal sw command
