xline blocked
  • Thread starter Thread starter francesco.livotto
francesco.livotto
good morning, point in white I found myself using this command and once selected the first point of origin in indicating the second point the line assumes a different behavior from the usual blocking itself vertically or horizontally.
Can anyone explain what I've done? Thank you.
I press that I use little and nothing this command, but doing a test, if I type the command "xline" and click directly to draw, creates the line and gives me the possibility to choose the second point (sx lines of the attached photo), while if I type the command and choose one of the "vertical" modes "horizontal" creates a line on the respective axis chosen without possibility to choose the second point (line)aaaa.webp
hi, the line of construction remains locked horizontally or vertically with center on the cursor.
typing the xlinea keyboard command what comes out is this:
command: xlinea
specify a point or [ORizz/Vert/Ang/Bisett/OFfset]:
And here I go to define a point of ornaments. . .
specify step point:
at this time I normally displayed a straight that was joining the pointer, actually now I see
a straight that is drawn when I define the point of passage but only horizontally or vertically.
it is good education to thank and give feedback to the advice you are given. We are not working for you, indeed we are not working at all! ! !
the forum:-It is not a place where a question arises (maybe even insisting) and once you get the answer you no longer feel, without even saying thank you. thank you is a form of respect and gratitude.
- It's not a place of robbery, where I just need to go and then I disappear until the need arises.
the above phrases are drawn from This is post
Hi, I apologize but unfortunately I couldn't read all the posts related to what you sent me, among other things all in English so I'm trying to understand.
I tried to turn off the perpendicular snap but nothing changes. Thanks again.
