x11start
Drawing the armor of reinforced concrete elements, I must give the ferraioli the size of the iron brackets. for a pillar 50 x 50 cm, the inner bracket will be 45 x 45 cm; this because in the ordinary armor it takes 2,5 cm per part of cover.
sometimes an armor with a 4 cm headgear is required, in case a fire resistance is required (the above bracket would become 42 x 42 cm).
I currently draw the armor in scale and quot the iron that I designed, however when I have to go to the fire-resistant armor, I must necessarily "draw" all the quotas.... with the danger of forgetting some!
I wonder: is there the possibility of "binding" the text that indicates the type of spacer (2.5 or 4 cm) to the armor texts? i.e. it is possible (maybe with the "data field"), to indicate a type formula: larg.pilastro - spacer x 2.
This would allow me to change all measures that have this formula .... simply by changing the number regarding the spacer.
Thank you in advance.
