zero in a dwg file the total editing time data
  • Thread starter Thread starter vegeth
vegeth
Good morning to all,
I have this working necessities, I have created a dwg file with autocad 2009 as a basis to create other designs, I need to know how much time I use for a job and until here no problem because I use the time command, I can see the actual time in real time or zero everything and until here there is no problem.
when the file is saved, I click on it with the right mouse button (downside menu), click on properties, drop down statistics and I find the total editing time e.g. 9minuti.(which corresponds exactly to the time command autocad) and here come to my problem, I this drawing base (practically a master) I have to copy it to create another identical time with in addition of other things... after in a few words I have to reset the time of the master so that doing any copy, the copy in question always starts me from a time zero! I hope to be explained.
Thank you all for the availability as usual.
Unfortunately there is no command or variable to reset the total change time. is not expected.
but it is possible to solve the problem in This way:
how to reset the "total editing time" in an autocad dwg drawing?
in every autocad dwg file there is n automatic counter of cumulative total time spent on editing of that particular drawing in autocad. the information - "total editing time" - is then displayed in the time command.
this counter cannot be normally stopped or reset (cleared). but if you want reset this time for any reason, you can use the following method.
first save your current drawing (to be reset). use the new command to start a new drawing. on the "select template" prompt switch from the dwt to the dwg type and choose your previously saved drawing. using these steps you will start editing of a new drawing (with the time cleared) containing complete data from your original dwg drawing.
