Latest activity
  • jenuary replied to the thread problem print view trimmed.
    Have you tried to right-click on the line? even if I don't believe you let her select
  • jenuary replied to the thread solidworks24 properties from files.
    hi sincerely I do not realize that in 2024 they have changed something about custom properties. I did a test just before I answered you...
  • GP. replied to the thread id field with local ucs.
    Please: It remains a mystery as autocad can do similar things.
    Well, exporting autocad settings and reimporting them to the new one should be very little to fix. . . However, do not reinstall, I...
    I explain some things, ryof e w2u are two functions of the autocad geometric calculator (geomcal), from the command line you launch by...
  • Peppe replied to the thread export idw to excel sheet.
    the table is not a problem, you create one with the fields in the new language. for the distinction it is enough to export from together...
  • freexf replied to the thread in the explosive welds do not move.
    explosives only command components. You can hide the welds.
    campodate formulain the formula write ryof(w2u(mouse button in the formula and choose enter data field... objectselect the...
  • jenuary replied to the thread symbol in combination.
    I heard of macros in the feature manager that empty your current account :roflmao::roflmao::roflmao:
  • Peppe replied to the thread design design.
    on the network as well as on the forum there are many documents or examples of technical drawing. the right approach, given your young...
  • Fabietto replied to the thread design design.
    Okay, so... - better move the discussion on inventor, or better in students etc.. - as already said, the cross that unites the hubs must...
    hello usually that is an icon that keeps saved attributes and parameters of the part. I explain better...by macro you can save within...
    Hi, it doesn't seem to have been used as a creo for modeling and putting on the table. rather a cad 2d the discussion should be moved to...
  • MFT replied to the thread tariff for plasma bench design.
    but what it means, if I make you a quote and then keep making me make changes and hours become double. You pay me? I take for granted...
    I think it depends on the quality of work. those are projects, unless you have a previous reference, to be considered as a special...
